Problem using proxies
September 26, 2010 10:52AM
now my problem is that i'm using a proxy list with few bad proxies. Only few of them are bad, but they void lots of files!
I have to check bed proxies every few hours and to resume interrupted download (see the image)...
i set retry to -1 but some proxy even block more than 1 file...
A second problem is that the sorting doesn't work on the connection column.
PS: i'm using uploading.com plugin.
Edited 1 time(s). Last edit at 09/26/2010 10:53AM by brazoayeye.
open | download - Schermata.png (154.2 KB)
Re: Problem using proxies
September 26, 2010 11:21AM
Rule #1 with proxies - use your own and working transparent web proxies. We are not responsible for that. If you don't have it, don't use it.
Please define "doesn't work"
Edited 2 time(s). Last edit at 09/26/2010 11:22AM by Vity.
September 26, 2010 11:29AM
ok, but there isn't a way to bypass the error?
The arrow appears but files are not ordered. If i click another time the arrow turns, but files are not ordered again.
September 26, 2010 11:39AM
Sure there is. Don't violate rule #1 smiling smiley. Find some info on the web how transparent web proxy works.
I tried it and it works to me. It will be probably more complex problem.
Edited 1 time(s). Last edit at 09/26/2010 11:40AM by Vity.
September 26, 2010 01:11PM
>>Sure there is. Don't violate rule #1. Find some info on the web how transparent web proxy works.
I know how transparent proxies works: like anonimous, elite or distorting. The difference is only about the information sent...
If i bought a list of anon proxies will it not works? Most of them works, only few have that problem... (maybe they are a specific type of proxy?)
Thanks!
