Error- plugin implemention problem
Posted by gaio
January 17, 2009 05:07PM
i use 0.71 version, but on 0.80 i have the same error when i am downloading from easy-share
any one kwow how can i solve this problem
Re: Error- plugin implemention problem
January 19, 2009 02:23PM
yep...same problem here. But i think it only began to appear from today, cause they changed the way of waiting.
I am using the 0.81 version.
I think a plugin update is needed from the developer !
January 19, 2009 02:40PM
we have some terms this week. You have to be patient guys... Or you can learn Java and plugin API and fix it smiling smiley. The source code is open winking smiley.
Edited 1 time(s). Last edit at 01/19/2009 02:41PM by Vity.
January 21, 2009 12:57PM
for me it's easier to use another program than learning Java :D
January 27, 2009 07:38AM
not it's working but not properly ... unfortunately.
It gives an error : Failed to load captcha picture.
If i'm goinf in internet explorer and paste the link everything works just fine.
January 29, 2009 08:52AM
easy-share not working again...
Error: Plugin implementation error
...from the first attempt
