Disabling Sound confused smiley
Posted by Yangrast
November 20, 2010 08:19PM
How to disable sound? i mean the voice informing "file added" "starting to download" etc xD
Re: Disabling Sound confused smiley
November 20, 2010 08:39PM
Search forum or upgrade to the latest version.
Re: Disabling Sound
November 21, 2010 12:49AM
I'm using latest version (0.85-555). I've searched on forum, it say that can be disabled on "user settings" but i can't find that option. Btw, i saw that thread about where are those sound files located (inside frd.jar), and i've renamed them, but that generate an error of course. Any advice about an elegant solution? confused smiley
Thks, anyway.
Re: Disabling Sound
November 21, 2010 01:17AM
File startup.properties, set -DdetectBlindMode=false (last line)
