I need help 0.85ui (urgent)
Posted by djcave007
February 01, 2011 03:24PM
The problem is simple. The fr was bigger than my desktop.
I'll put a print and you tell me what can be.
I see no menus or buttons, and the names of the files are larger than the screen.
Help me please
Re: I need help 0.85ui (urgent)
February 01, 2011 03:32PM
Up????
February 05, 2011 05:33PM
press F11 to see menu again
resize columns by dragging the bar between nome and progresso
hope this helps
February 08, 2011 02:29PM
Hey philphil61
I did it. but without results, I see it appears that the columns were much larger than his own program, do not know what else to do ....
February 09, 2011 11:02AM
so FRD is bigger than your screen?
if so try this first
go to start menu - right click the shortcut to FRD - select properties
you can try 2 options - first - select Run Maximised (from the drop down menu half way down the properties box) - click Apply - click OK - restart FRD
if that didn't fix it go back to shortcut - right click - select properties - select Run Normal - click Apply - click OK - restart FRD
if neither option restored your FRD to full screen try this (again) go to start menu - right click the shortcut to FRD - select properties - in the Target address (reads something like "C:\Program Files\FreeRapid Downloader\frd.exe") add " -start-maximized" without the quotes but note the space
example "C:\Program Files\FreeRapid Downloader\frd.exe" -start-maximized
click apply - click OK
Hope it works for you - if not check your screen resolution and repost here the setting.
February 11, 2011 06:13PM
Hey Philphil61....!!!
Tanks for a Help!
Does not work on your own, but his idea of resolution has helped me, I reversed the option screen to portrait and was decreasing window of FRD and that was it and it worked.
Sorry for english, I'm Brazilian (Google Translator)
kkkkkkkkkk
Tanks Man!!!!
Edited 2 time(s). Last edit at 02/11/2011 06:25PM by djcave007.
February 14, 2011 06:29AM
Good that you have it solved.....
Do not concern yourself about your English.... and the translation... all is good ;)
