not starting
November 13, 2011 09:28PM
hi
i get always following message if i want to start frd.exe or frd.jar:
"you are not using sun java, but oracle corporation Seee readme.txt...."
but i installed Java Sun 7.1 and 6.27 and i use it
what to do?
Re: not starting
November 13, 2011 09:34PM
Try to use start.bat.
Something is probably blocking frd.exe (antivirus probably).
Re: not starting
November 13, 2011 09:42PM
hhmm what start.bat?
i tried with inactive anti-virus without success
the same fault :(
i installed Java now new
maybe because java sun, doesn't exist anymore, its a part of oracle now?
Edited 1 time(s). Last edit at 11/13/2011 09:51PM by zaplcgn.
Re: not starting
November 13, 2011 09:51PM
File start.bat is located in FRD's directory. If it fails it means you (probably) installed Java Runtime files incorrectly. Try to reinstall it.
Edited 1 time(s). Last edit at 11/13/2011 09:58PM by Vity.
Re: not starting
November 13, 2011 10:07PM
hmm i uninstalled my download version and installed now directly from your page, there is an start.bat included :)
but now i works without the start.bat
shit happens with the other download from [hackerthedude.blogspot.com]
