Problems with Megaupload
Posted by chavoni
March 06, 2009 03:12PM
when the file contains password security can not download, any solution
EX - [www.megaupload.com]
PWD - HPQ3964A1
thanks
Re: Problems with Megaupload
March 06, 2009 04:48PM
You should upgrade to version 1.7.1.
Edited 1 time(s). Last edit at 03/06/2009 05:33PM by Vity.
March 10, 2009 02:47PM
The captcha in the new megaupload website is new, is there any update that can automatically catch this? Its frustrating to keep on entering the captcha.
March 10, 2009 02:52PM
March 16, 2009 10:34AM
I'm not talking about the capcha automatic, but the password to download the same file, where type this password?
Have an example in my first post.
March 17, 2009 01:11AM
OK. It's a bug. Lukiz will fix it ASAP.
Thanks for reporting.
March 17, 2009 12:10PM
You have to change to another LookAndFeel. It seems that Substance contains a bug.
March 17, 2009 02:48PM
pwd - 013607g
March 23, 2009 01:28AM
something new
March 23, 2009 01:33AM
As I wrote before, change the look and feel.
I plan some minor changes in 0.82 to handle this problem in Substance.
