problem with ceskatelevize.cz
Posted by gogo
Re: problem with ceskatelevize.cz
April 13, 2014 06:26AM
@ha_pi_pi
Yes I can download them without problem. The problem you're having is : "java.net.ConnectException: Connection timed out: connect". That means FRD unable to connect to server within a certain time limit. Are you using antivirus/firewall? If so, make sure FRD is in the whitelist. Also ceskatelevize plugin uses RTMP port 1935, make sure to configure your firewall to open port 1935.
Edited 1 time(s). Last edit at 04/13/2014 06:28AM by tong2shot.
April 14, 2014 05:43PM
@tong2shot
You are absolutely right. The problem is port 1935. I'm so sorry I have troubled you with this, it's my own problem only I did not realize it.
Thank you for all your time.
April 14, 2014 10:37PM
No problem.
Glad the problem is solved. Thanks for the feedback.
July 26, 2014 12:31PM
Sometimes it shows error something like "Chyba - RTMP ERROR - IOException - Pipe broken".
It downloads about 1 percent (2 MB ).
Now it shows about 3 times. It needs ignore error,and resend request to byte,what is not properly backed.
Edited 2 time(s). Last edit at 07/26/2014 12:34PM by ad48.
July 26, 2014 12:37PM
LOG
Caused by: java.io.IOException: Na disku není dost místa
at java.io.RandomAccessFile.writeBytes(Native Method)
at java.io.RandomAccessFile.write(Unknown Source)
at com.objectdb.o.LFL.P(LFL.java:938)
... 22 more
Sat Jul 26 14:28:01 CEST 2014 WARNING: Couldn't create fir C:\Users\ad48\AppData\Roaming\VitySoft\FRD
Sat Jul 26 14:28:11 CEST 2014 WARNING: Couldn't create fir C:\Users\ad48\AppData\Roaming\VitySoft\FRD
Sat Jul 26 14:28:15 CEST 2014 SEVERE:
cz.vity.freerapid.plugins.exceptions.PluginImplementationException: RTMP error - IOException: Pipe broken
at cz.vity.freerapid.plugins.services.rtmp.AbstractRtmpRunner.tryDownloadAndSaveFile(Unknown Source)
at cz.vity.freerapid.plugins.services.ceskatelevize.CeskaTelevizeFileRunner.run(Unknown Source)
at cz.vity.freerapid.plugins.webclient.AbstractFileShareService.run(AbstractFileShareService.java:102)
at cz.vity.freerapid.core.tasks.DownloadTask.doInBackground(DownloadTask.java:98)
at cz.vity.freerapid.core.tasks.DownloadTask.doInBackground(DownloadTask.java:42)
at javax.swing.SwingWorker$1.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at javax.swing.SwingWorker.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
Sat Jul 26 14:31:48 CEST 2014 SEVERE:
java.io.IOException: Pipe broken
at java.io.PipedInputStream.read(Unknown Source)
at java.io.InputStream.read(Unknown Source)
at cz.vity.freerapid.core.tasks.DownloadTask.saveToFile(DownloadTask.java:242)
Sat Jul 26 14:31:48 CEST 2014 WARNING: Content from the last request
Slečna Zazi
[imgct.ceskatelevize.cz]
Sat Jul 26 14:31:58 CEST 2014 SEVERE:
Sat Jul 26 14:31:58 CEST 2014 WARNING: Content from the last request
Slečna Zazi
July 26, 2014 01:03PM
"Na disku není dost místa" -> Are you sure your hard disk is not full?
July 27, 2014 10:15AM
Harddisk (download path) is have lot of space. But disk C have 0 bytes. FRD shows message boxs. Then i remove some files from C,and i have space about 400MB. FRD stop showing message boxs. Then links randomly crash. Now,i test it again,and it again dont working.
Free space
C
3,49 GB
H
about 582 GB
Log
Sun Jul 27 12:01:43 CEST 2014 WARNING: Couldn't create fir C:\Users\ad48\AppData\Roaming\VitySoft\FRD
Sun Jul 27 12:03:24 CEST 2014 SEVERE: cz.vity.freerapid.core.tasks.DownloadTask@23b923 failed: java.net.ConnectException: Connection timed out: connect
at java.net.DualStackPlainSocketImpl.connect0(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at java.net.Socket.(Unknown Source)
at org.apache.commons.httpclient.protocol.DefaultProtocolSocketFactory.createSocket(DefaultProtocolSocketFactory.java:80)
at org.apache.commons.httpclient.protocol.DefaultProtocolSocketFactory.createSocket(DefaultProtocolSocketFactory.java:122)
at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707)
at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387)
at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171)
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397)
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:323)
at cz.vity.freerapid.plugins.webclient.DownloadClient.processHttpMethod(DownloadClient.java:376)
at cz.vity.freerapid.plugins.webclient.DownloadClient.makeRequestFile(DownloadClient.java:192)
at cz.vity.freerapid.plugins.webclient.DownloadClient.makeFinalRequestForFile(DownloadClient.java:179)
at cz.vity.freerapid.plugins.webclient.AbstractRunner.tryDownloadAndSaveFile(AbstractRunner.java:412)
at cz.vity.freerapid.plugins.services.ulozto.UlozToRunner.run(Unknown Source)
Sun Jul 27 12:05:02 CEST 2014 SEVERE:
Sun Jul 27 12:05:02 CEST 2014 WARNING: Content from the last request
Slečna Zazi
Sun Jul 27 12:05:49 CEST 2014 SEVERE:
Sun Jul 27 12:05:49 CEST 2014 WARNING: Content from the last request
Slečna Zazi
Sun Jul 27 12:05:55 CEST 2014 SEVERE:
Sun Jul 27 12:05:55 CEST 2014 WARNING: Content from the last request
Slečna Zazi
Sun Jul 27 12:07:02 CEST 2014 SEVERE: cz.vity.freerapid.core.tasks.DownloadTask@19a7e8f failed: java.io.IOException: ErrorDuringDownload
at cz.vity.freerapid.core.tasks.DownloadTask.saveToFile(DownloadTask.java:263)
at cz.vity.freerapid.plugins.webclient.AbstractRunner.tryDownloadAndSaveFile(AbstractRunner.java:415)
Sun Jul 27 12:07:52 CEST 2014 SEVERE: cz.vity.freerapid.core.tasks.DownloadTask@12fe1e5 failed: java.io.IOException: ErrorDuringDownload
Sample links (download links)
[www.ceskatelevize.cz]
Stop at
1. 3 percent - about 4MB
2 .2 percent - about 3MB
3 .1 percent - about 1MB
Free memory 1413 (MB ).
That´s lots of information.
Edited 1 time(s). Last edit at 07/27/2014 10:17AM by ad48.
July 27, 2014 10:25AM
Today is last day to fix,because next day be one of episodes removed.
July 27, 2014 11:12AM
I downloaded two files successfully. I got the same error on the third file at 90%. I will try to debug this.
Here's a download link for the first one: [mega.co.nz]
July 27, 2014 11:46AM
I am on "hotel" wifi,downloading is slow (about 20KB per second),at home it is about 200KB per second.
