Česká televize plugin does not work
Posted by Guylub
Re: Česká televize plugin does not work
July 20, 2018 07:29AM
I confirm the problem with plugin ceskatelevize.cz. Sample link [www.ceskatelevize.cz].
Plugin version 2.1.7, software version 0.9u4. Message: "Error loading playlist url".
July 20, 2018 11:16AM
Totally the same problem. FRD 0.9u4 + ceskatelevize.cz plugin 2.1.7 = CHYBA - Error loading playlist URL
July 20, 2018 04:22PM
I confirm ceskatelevize.cz not working.
July 22, 2018 11:37AM
Can not download address: [www.ceskatelevize.cz]
Plugin - ceskatelevize.cz
Version: 2.1.7
FreeRapid 0.9u4
Please update the plugin and fix the problem. sad smiley
July 22, 2018 11:39AM
Plugin Version: 2.1.7
FreeRapid 0.9u4
Plugin version 2.1.7 is not functional since July 20, 2018. Please update the plugin and fix the problem. sad smiley
Edited 2 time(s). Last edit at 07/22/2018 12:05PM by Guylub.
July 23, 2018 04:39PM
Verze FRD 0.8.0.0.
ceskatelevize.cz 2.1.7
Odkaz se načte, ale stahování neproběhne, hlásí to " Chyba - Error loading playlist URL "
Přestalo to fungovat asi před dvěma dny, prosím o aktualizaci pluginu.
Sun Jul 22 14:47:19 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 14:48:49 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 14:50:49 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 14:52:19 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 18:48:49 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 20:24:49 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 20:25:19 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 21:46:20 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 21:52:46 CEST 2018 SEVERE: Status code je 500
Sun Jul 22 21:52:46 CEST 2018 WARNING: Error getting playlist for: 720p (2300 kbps)
Sun Jul 22 21:52:46 CEST 2018 WARNING: Error getting playlist for: 1080p (3300 kbps)
Sun Jul 22 21:52:50 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 21:54:49 CEST 2018 SEVERE: Status code je 500
Sun Jul 22 21:54:49 CEST 2018 WARNING: Error getting playlist for: 720p (2300 kbps)
Sun Jul 22 21:54:49 CEST 2018 WARNING: Error getting playlist for: 1080p (3300 kbps)
Sun Jul 22 21:54:50 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 21:55:50 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 21:55:55 CEST 2018 SEVERE: Status code je 500
Sun Jul 22 21:55:55 CEST 2018 WARNING: Error getting playlist for: 720p (2300 kbps)
Sun Jul 22 21:55:55 CEST 2018 WARNING: Error getting playlist for: 1080p (3300 kbps)
Sun Jul 22 21:58:11 CEST 2018 SEVERE: Status code je 500
Sun Jul 22 21:58:11 CEST 2018 WARNING: Error getting playlist for: 720p (2300 kbps)
Sun Jul 22 21:58:11 CEST 2018 WARNING: Error getting playlist for: 1080p (3300 kbps)
Sun Jul 22 21:58:20 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 21:59:05 CEST 2018 WARNING: SimpleHttpConnectionManager being used incorrectly. Be sure that HttpMethod.releaseConnection() is always called and that only one thread and/or method is using this connection manager at a time.
Sun Jul 22 21:59:06 CEST 2018 SEVERE: Status code je 500
Sun Jul 22 21:59:20 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 21:59:31 CEST 2018 WARNING: SimpleHttpConnectionManager being used incorrectly. Be sure that HttpMethod.releaseConnection() is always called and that only one thread and/or method is using this connection manager at a time.
Sun Jul 22 21:59:31 CEST 2018 SEVERE: Status code je 500
Sun Jul 22 21:59:50 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 21:59:52 CEST 2018 WARNING: SimpleHttpConnectionManager being used incorrectly. Be sure that HttpMethod.releaseConnection() is always called and that only one thread and/or method is using this connection manager at a time.
Sun Jul 22 21:59:52 CEST 2018 SEVERE: Status code je 500
Sun Jul 22 22:02:34 CEST 2018 WARNING: SimpleHttpConnectionManager being used incorrectly. Be sure that HttpMethod.releaseConnection() is always called and that only one thread and/or method is using this connection manager at a time.
Sun Jul 22 22:02:34 CEST 2018 SEVERE: Status code je 500
Sun Jul 22 22:02:50 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 22:04:03 CEST 2018 WARNING: SimpleHttpConnectionManager being used incorrectly. Be sure that HttpMethod.releaseConnection() is always called and that only one thread and/or method is using this connection manager at a time.
Sun Jul 22 22:04:03 CEST 2018 SEVERE: Status code je 500
Sun Jul 22 22:04:20 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 22:05:25 CEST 2018 WARNING: Invalid URL - 'http://www.w3.org/MarkUp/DTD/xhtml-rdfa-1.dtd"><!--[if lt IE 7 ]> <![endif]-->' does not match URI specification
Sun Jul 22 22:09:39 CEST 2018 WARNING: SimpleHttpConnectionManager being used incorrectly. Be sure that HttpMethod.releaseConnection() is always called and that only one thread and/or method is using this connection manager at a time.
Sun Jul 22 22:09:40 CEST 2018 SEVERE: Status code je 500
Sun Jul 22 22:09:50 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 22:34:20 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 22:41:50 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 22:44:20 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 22:48:50 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Mon Jul 23 02:48:50 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Mon Jul 23 06:48:50 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Mon Jul 23 10:48:53 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Mon Jul 23 14:48:53 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Mon Jul 23 14:49:00 CEST 2018 SEVERE:
java.net.UnknownHostException: wordrider.net
at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at java.net.Socket.(Unknown Source)
at org.apache.commons.httpclient.protocol.DefaultProtocolSocketFactory.createSocket(DefaultProtocolSocketFactory.java:80)
at org.apache.commons.httpclient.protocol.ControllerThreadSocketFactory$1.doit(ControllerThreadSocketFactory.java:91)
at org.apache.commons.httpclient.protocol.ControllerThreadSocketFactory$SocketTask.run(ControllerThreadSocketFactory.java:158)
Mon Jul 23 14:49:23 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Mon Jul 23 15:49:00 CEST 2018 SEVERE:
Mon Jul 23 15:49:23 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Mon Jul 23 16:49:24 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Mon Jul 23 18:13:32 CEST 2018 SEVERE: Status code je 500
Mon Jul 23 18:13:32 CEST 2018 WARNING: Error getting playlist for: 720p (2300 kbps)
Mon Jul 23 18:13:32 CEST 2018 WARNING: Error getting playlist for: 1080p (3300 kbps)
Mon Jul 23 18:13:54 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Mon Jul 23 18:15:49 CEST 2018 SEVERE: Status code je 500
Mon Jul 23 18:15:49 CEST 2018 WARNING: Error getting playlist for: 720p (2300 kbps)
Mon Jul 23 18:15:49 CEST 2018 WARNING: Error getting playlist for: 1080p (3300 kbps)
Mon Jul 23 18:15:54 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Mon Jul 23 18:20:40 CEST 2018 WARNING: SimpleHttpConnectionManager being used incorrectly. Be sure that HttpMethod.releaseConnection() is always called and that only one thread and/or method is using this connection manager at a time.
Mon Jul 23 18:20:40 CEST 2018 SEVERE: Status code je 500
Mon Jul 23 18:20:54 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Mon Jul 23 18:24:23 CEST 2018 WARNING: SimpleHttpConnectionManager being used incorrectly. Be sure that HttpMethod.releaseConnection() is always called and that only one thread and/or method is using this connection manager at a time.
Mon Jul 23 18:24:23 CEST 2018 SEVERE: Status code je 500
Mon Jul 23 18:24:24 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Mon Jul 23 18:24:55 CEST 2018 WARNING: SimpleHttpConnectionManager being used incorrectly. Be sure that HttpMethod.releaseConnection() is always called and that only one thread and/or method is using this connection manager at a time.
Mon Jul 23 18:24:56 CEST 2018 SEVERE: Status code je 500
July 24, 2018 03:48PM
I also confirm the problem with plugin ceskatelevize.cz. Sample link [www.ceskatelevize.cz].
I really need it for my summer course. Please fixed it.
July 24, 2018 04:43PM
Plugin v2.1.8 should work again. smiling smiley
September 13, 2018 04:24PM
Good day.
Ceska televize plugin not working on these links (Error getting playlist URL):
- [www.ceskatelevize.cz] - for this video please create filename "1973 - Jaderná elektrárna Jaslovské Bohunice.ts".
- [www.ceskatelevize.cz] - for this video please create filename "Čtvrtek 12. září 1968 17 30 - Týden ve filmu.ts".
With others links plugin working without problems.
Please add support for these types of links (they are new on the web ceskatelevize.cz).
Application version 0.9u4, plugin version last 2.1.8.
Edited 2 time(s). Last edit at 09/13/2018 04:27PM by mirij.
September 29, 2018 07:41PM
I cannot download this CT
Getting error javalangRuntimeException:Couldnt generate DH keypair.
Plugin ver. 2.1.8.
