Verze FRD 0.8.0.0.
ceskatelevize.cz 2.1.7
Odkaz se načte, ale stahování neproběhne, hlásí to " Chyba - Error loading playlist URL "
Přestalo to fungovat asi před dvěma dny, prosím o aktualizaci pluginu.
Sun Jul 22 14:47:19 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 14:48:49 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 14:50:49 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 14:52:19 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 18:48:49 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 20:24:49 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 20:25:19 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 21:46:20 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 21:52:46 CEST 2018 SEVERE: Status code je 500
Sun Jul 22 21:52:46 CEST 2018 WARNING: Error getting playlist for: 720p (2300 kbps)
Sun Jul 22 21:52:46 CEST 2018 WARNING: Error getting playlist for: 1080p (3300 kbps)
Sun Jul 22 21:52:50 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 21:54:49 CEST 2018 SEVERE: Status code je 500
Sun Jul 22 21:54:49 CEST 2018 WARNING: Error getting playlist for: 720p (2300 kbps)
Sun Jul 22 21:54:49 CEST 2018 WARNING: Error getting playlist for: 1080p (3300 kbps)
Sun Jul 22 21:54:50 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 21:55:50 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 21:55:55 CEST 2018 SEVERE: Status code je 500
Sun Jul 22 21:55:55 CEST 2018 WARNING: Error getting playlist for: 720p (2300 kbps)
Sun Jul 22 21:55:55 CEST 2018 WARNING: Error getting playlist for: 1080p (3300 kbps)
Sun Jul 22 21:58:11 CEST 2018 SEVERE: Status code je 500
Sun Jul 22 21:58:11 CEST 2018 WARNING: Error getting playlist for: 720p (2300 kbps)
Sun Jul 22 21:58:11 CEST 2018 WARNING: Error getting playlist for: 1080p (3300 kbps)
Sun Jul 22 21:58:20 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 21:59:05 CEST 2018 WARNING: SimpleHttpConnectionManager being used incorrectly. Be sure that HttpMethod.releaseConnection() is always called and that only one thread and/or method is using this connection manager at a time.
Sun Jul 22 21:59:06 CEST 2018 SEVERE: Status code je 500
Sun Jul 22 21:59:20 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 21:59:31 CEST 2018 WARNING: SimpleHttpConnectionManager being used incorrectly. Be sure that HttpMethod.releaseConnection() is always called and that only one thread and/or method is using this connection manager at a time.
Sun Jul 22 21:59:31 CEST 2018 SEVERE: Status code je 500
Sun Jul 22 21:59:50 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 21:59:52 CEST 2018 WARNING: SimpleHttpConnectionManager being used incorrectly. Be sure that HttpMethod.releaseConnection() is always called and that only one thread and/or method is using this connection manager at a time.
Sun Jul 22 21:59:52 CEST 2018 SEVERE: Status code je 500
Sun Jul 22 22:02:34 CEST 2018 WARNING: SimpleHttpConnectionManager being used incorrectly. Be sure that HttpMethod.releaseConnection() is always called and that only one thread and/or method is using this connection manager at a time.
Sun Jul 22 22:02:34 CEST 2018 SEVERE: Status code je 500
Sun Jul 22 22:02:50 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 22:04:03 CEST 2018 WARNING: SimpleHttpConnectionManager being used incorrectly. Be sure that HttpMethod.releaseConnection() is always called and that only one thread and/or method is using this connection manager at a time.
Sun Jul 22 22:04:03 CEST 2018 SEVERE: Status code je 500
Sun Jul 22 22:04:20 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 22:05:25 CEST 2018 WARNING: Invalid URL - 'http://www.w3.org/MarkUp/DTD/xhtml-rdfa-1.dtd"><!--[if lt IE 7 ]> <![endif]-->' does not match URI specification
Sun Jul 22 22:09:39 CEST 2018 WARNING: SimpleHttpConnectionManager being used incorrectly. Be sure that HttpMethod.releaseConnection() is always called and that only one thread and/or method is using this connection manager at a time.
Sun Jul 22 22:09:40 CEST 2018 SEVERE: Status code je 500
Sun Jul 22 22:09:50 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 22:34:20 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 22:41:50 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 22:44:20 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Sun Jul 22 22:48:50 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Mon Jul 23 02:48:50 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Mon Jul 23 06:48:50 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Mon Jul 23 10:48:53 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Mon Jul 23 14:48:53 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Mon Jul 23 14:49:00 CEST 2018 SEVERE:
java.net.UnknownHostException: wordrider.net
at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at java.net.Socket.
(Unknown Source)
at java.net.Socket.(Unknown Source)
at org.apache.commons.httpclient.protocol.DefaultProtocolSocketFactory.createSocket(DefaultProtocolSocketFactory.java:80)
at org.apache.commons.httpclient.protocol.ControllerThreadSocketFactory$1.doit(ControllerThreadSocketFactory.java:91)
at org.apache.commons.httpclient.protocol.ControllerThreadSocketFactory$SocketTask.run(ControllerThreadSocketFactory.java:158)
Mon Jul 23 14:49:23 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Mon Jul 23 15:49:00 CEST 2018 SEVERE:
Mon Jul 23 15:49:23 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Mon Jul 23 16:49:24 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Mon Jul 23 18:13:32 CEST 2018 SEVERE: Status code je 500
Mon Jul 23 18:13:32 CEST 2018 WARNING: Error getting playlist for: 720p (2300 kbps)
Mon Jul 23 18:13:32 CEST 2018 WARNING: Error getting playlist for: 1080p (3300 kbps)
Mon Jul 23 18:13:54 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Mon Jul 23 18:15:49 CEST 2018 SEVERE: Status code je 500
Mon Jul 23 18:15:49 CEST 2018 WARNING: Error getting playlist for: 720p (2300 kbps)
Mon Jul 23 18:15:49 CEST 2018 WARNING: Error getting playlist for: 1080p (3300 kbps)
Mon Jul 23 18:15:54 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Mon Jul 23 18:20:40 CEST 2018 WARNING: SimpleHttpConnectionManager being used incorrectly. Be sure that HttpMethod.releaseConnection() is always called and that only one thread and/or method is using this connection manager at a time.
Mon Jul 23 18:20:40 CEST 2018 SEVERE: Status code je 500
Mon Jul 23 18:20:54 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Mon Jul 23 18:24:23 CEST 2018 WARNING: SimpleHttpConnectionManager being used incorrectly. Be sure that HttpMethod.releaseConnection() is always called and that only one thread and/or method is using this connection manager at a time.
Mon Jul 23 18:24:23 CEST 2018 SEVERE: Status code je 500
Mon Jul 23 18:24:24 CEST 2018 WARNING: Couldn't create fir C:\Users\HP\AppData\Roaming\VitySoft\FRD
Mon Jul 23 18:24:55 CEST 2018 WARNING: SimpleHttpConnectionManager being used incorrectly. Be sure that HttpMethod.releaseConnection() is always called and that only one thread and/or method is using this connection manager at a time.
Mon Jul 23 18:24:56 CEST 2018 SEVERE: Status code je 500
