youtube plugin problems December 01, 2018 07:25PM |
Re: youtube plugin problems December 01, 2018 08:49PM |
; are you on the very latest Java version (8u191 or 8u192) for your OS and architecture? I am afraid I'm not able to offer a permanent remedy for this; a dev has to identify the cause of it and fix it with new code...
Re: youtube plugin problems December 01, 2018 11:48PM |
Re: youtube plugin problems December 02, 2018 03:30AM |
Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 (isom/mp42) File size : 51.5 MiB Duration : 23 min 0 s Overall bit rate mode : Variable Overall bit rate : 313 kb/s Encoded date : UTC 2018-10-28 08:58:00 Tagged date : UTC 2018-10-28 08:58:00 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Baseline@L3 Format settings : 1 Ref Frames Format settings, CABAC : No Format settings, ReFrames : 1 frame Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 23 min 0 s Bit rate : 215 kb/s Width : 640 pixels Height : 360 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 (30000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.031 Stream size : 35.3 MiB (69%) Title : ISO Media file produced by Google Inc. Created on: 10/28/2018. Encoded date : UTC 2018-10-28 08:58:00 Tagged date : UTC 2018-10-28 08:58:00 Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Codec configuration box : avcC Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : mp4a-40-2 Duration : 23 min 0 s Bit rate mode : Variable Bit rate : 96.0 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 SPF) Compression mode : Lossy Stream size : 15.8 MiB (31%) Title : ISO Media file produced by Google Inc. Created on: 10/28/2018. Encoded date : UTC 2018-10-28 08:58:00 Tagged date : UTC 2018-10-28 08:58:00
When the two streams have finished downloading (in my case, it took 16min!), they'll be muxed (packaged) into a single MP4 file, sized 38.5 MiB; here is its MediaInfo log:
Format : MPEG-4 Format profile : Base Media Codec ID : isom (isom/iso2/avc1) File size : 38.5 MiB Duration : 23 min 0 s Overall bit rate : 234 kb/s Encoded date : UTC 2018-12-02 02:52:24 Tagged date : UTC 2018-12-02 02:52:24 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.1 Format settings : CABAC / 3 Ref Frames Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 23 min 0 s Bit rate : 103 kb/s Width : 854 pixels Height : 480 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 (30000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.008 Stream size : 17.0 MiB (44%) Encoded date : UTC 2018-10-28 08:55:18 Tagged date : UTC 2018-12-02 02:52:24 Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Codec configuration box : avcC Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : mp4a-40-2 Duration : 23 min 0 s Bit rate : 126 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 SPF) Compression mode : Lossy Stream size : 20.7 MiB (54%) Language : English Encoded date : UTC 2018-10-28 09:01:04 Tagged date : UTC 2018-12-02 02:52:24720p is available as both a standalone stream as well as DASH streams; as in the case of 360p, FRD will fetch the former; as you said, file size is 50.56 MB; MediaInfo log:
Format profile : Base Media / Version 2 Codec ID : mp42 (isom/mp42) File size : 50.6 MiB Duration : 23 min 0 s Overall bit rate mode : Variable Overall bit rate : 307 kb/s Encoded date : UTC 2018-10-28 09:05:52 Tagged date : UTC 2018-10-28 09:05:52 gsst : 0 gstd : 1380310 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.1 Format settings : CABAC / 3 Ref Frames Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 23 min 0 s Bit rate : 178 kb/s Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 (30000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.006 Stream size : 29.3 MiB (58%) Title : ISO Media file produced by Google Inc. Created on: 10/28/2018. Encoded date : UTC 2018-10-28 09:05:52 Tagged date : UTC 2018-10-28 09:05:52 Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Codec configuration box : avcC Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : mp4a-40-2 Duration : 23 min 0 s Bit rate mode : Variable Bit rate : 126 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 SPF) Compression mode : Lossy Stream size : 20.7 MiB (41%) Title : ISO Media file produced by Google Inc. Created on: 10/28/2018. Encoded date : UTC 2018-10-28 09:05:52 Tagged date : UTC 2018-10-28 09:05:52Your specific video isn't available in higher resolutions (> 720p).
360p Overall bit rate : 313 kb/s 480p Overall bit rate : 234 kb/s 720p Overall bit rate : 307 kb/s
Re: youtube plugin problems December 02, 2018 09:45PM |
Re: youtube plugin problems December 08, 2018 06:03AM |
