Problem with rapidshare.com
Posted by gilbert00
March 14, 2010 09:09AM
FRD 0.83u1
RapidShare.com 1.0.17
Error - Problem with a connection to service.
Cannot find requested page content
[rapidshare.com]
File is downloaded.by IE 8.0.
Edited 1 time(s). Last edit at 03/14/2010 09:36AM by gilbert00.
open | download - app.log (4.3 KB)
Re: Problem with rapidshare.com
March 14, 2010 09:34AM
The problem is in your internet connection, not FRD.
March 14, 2010 09:39AM
All files is downloaded.from rapidshare.com by IE 8.0, but not by FRD.
March 14, 2010 10:05AM
As the exceptions says, "Connection reset". Not related to FreeRapid's code. If you are dead set on that it's a problem with FRD, you should propably go report the problem to Apache, as the low-level network methods are handled by their code.
March 14, 2010 11:19AM
Probably proxy problem.
March 14, 2010 12:35PM
I don't have Apache. Where Apache is set?
March 14, 2010 12:41PM
FreeRapid uses Apache's low-level networking code, I meant.
March 14, 2010 01:17PM
Where is Apache in Windows? I didn't installed it.
March 14, 2010 01:40PM
ntoskrnl meant rapidshare servers
you probably don't have properly set your connection in FRD - proxy, see IE connection settings
March 14, 2010 02:47PM
In FRD options - connection i have "Use default system connection".
I wrote that files are downloaded well by IE, but NOT by FRD with same connection options!
Edited 1 time(s). Last edit at 03/14/2010 02:49PM by gilbert00.
