problems with file monster's patch
December 31, 2010 04:47PM
HI,i know this is a dumb question,but i saw in a topic a patch to fix file monster and other websites,i downloaded it,it was a .diff file i dont know how to apply it to the plugin.
i got it from this thread:Oron.com & hotfile.com not working
codeboy2k uploaded it,so please help me with this.
Thank you codeboy2k for uploading the patch.
Edited 1 time(s). Last edit at 12/31/2010 04:48PM by rami.
Re: problems with file monster's patch
January 01, 2011 05:51PM
It would involve getting checking out the SVN, applying the patch, and compiling... something quite involved.
Where is the thread you found the patch in and how old is it? I don't remember it.
January 01, 2011 10:52PM
it is in may 08 2010 and sry 4 asking but what is svn? i know i am a little dumb
January 02, 2011 10:29AM
If you don't know what it is, then you probably can't use the fix.
Could you post a link to the thread so I can take a look at it and possibly release a fixed plugin?
January 02, 2011 08:51PM
this is the link:[wordrider.net]
and thank you 4 helping me so far.
January 03, 2011 09:05AM
That patch does not fix the current problems with the plugin. It was a fix for a ReCaptcha issue, which has been released for a long while now.
January 03, 2011 01:58PM
but i have a problem it says: Error file name not found,what can i do to fix this
January 03, 2011 03:42PM
You can do nothing with it, the plugin is broken at the moment.
January 03, 2011 04:43PM
Thank u 4 all the help u have given me.Do u know when will it be fixed?
Edited 1 time(s). Last edit at 01/03/2011 04:43PM by rami.
January 03, 2011 08:00PM
Nope. There were some major issues with it IIRC, but I'm not sure.
