uloz.to doesn't work
Posted by wbali
June 12, 2012 01:54PM
I have FRD version 0.86u1
uloz.to plugin ver.1.0.28
I get "ERROR - Tag containing 'class="captcha" was not found!"
link for example: "http://uloz.to/xPb3es7/need-for-speed-carbon-razor1911-part2-rar"
Re: uloz.to doesn't work
June 12, 2012 06:28PM
same error
please help smiling smiley
Edited 1 time(s). Last edit at 06/12/2012 07:07PM by delihc.
June 13, 2012 06:18AM
Same problem sad smiley
June 13, 2012 07:04PM
Prosím prosím o aktualizaci pluginu...
June 14, 2012 03:05AM
thumbs up working link & app.log thumbs up
uloz.to plugin ver.1.0.29 should fix this problem
June 16, 2012 05:01AM
uloz.to plugin ver.1.0.30 - should now avoid the captcha
July 24, 2012 06:23AM
latest FRD version 0.86u1
latest plugin "uloz.to" ver.1.0.30
After many minutes i get error "bitstream errorcode 102"
links for example:
[www.ulozto.cz]
[www.ulozto.cz]
[www.ulozto.cz]
app.log is attached
Thanks for help.
open | download - app.log (22.5 KB)
July 24, 2012 06:51AM
Dev notes: Error 102 (actually 0x102) is STREAM_ERROR, which seems to be thrown only if an InputStream#read() method throws an IOException. The server probably closes the stream or something. I can't reproduce this though.
July 25, 2012 06:41AM
I did test the manual download on ulozto.cz site (I downloaded manualy for the last time about a year ago :) and found out, that the server is overloaded. On July 20th they upgraded, so nothing can be downloaded (or with problems).
Sorry, i didn't test at the first time, so I appologize.
It seems that the plugin is working, but I cannot test it before the server will be working.
August 01, 2012 12:37PM
Hello again,
so it seems, that uloz.to is working (with some problems), but plugin is not working. I tried manually and downloaded everything I want. Unfortunatelly the plugin shows an error "Bitstream errorcode 102" (it took a long time to show the error, more than 4 minutes is "Getting" - "Zjišťuje se"). So it is still the same problem as above.
You can try the links above or this one for example:
[www.ulozto.cz]
Thanks for correction.
