WordRider Questions...
September 04, 2007 08:33PM
Hello eye rolling smiley
First of all, I would like to sincerely thank the author(s) of WordRider for offering us a freeware application that can insert "image" files into our TI calculators without having to know BASic programming language~!
That being said, I find myself confused on exactly "how" to create notes and their underlying "images"--and then accessing them properly on my calculator!sad smiley
Here is the "Newbie" problem with using WordRider:
1. Followed "flash-based" tutorial, loaded WordRider on my PC and "archived" HibView/Lib-PreOS on my TI V200 (each now has the Root of "main\").....
Does this mean that we have to callup a command such as "hibview()" on the Home Screen---every time we need to view our created notes/images on the calc~?!!
(TI apps "notefolio and studycard" each create a file which is easily accessed from their respective programs via a dropdown menu--I see no indication that WordRider offers such a feature)
2. If "each" created note w/image has too have an individual folder (1 for text-1 for the image).....again, how is our created note easily viewed on calc under this method~?!
Forgive this novice inquisition, but all the available tutorials assume that the user is comfortable with the various appys mentioned....and unfortunately I am not!
I thank you for any help with this matter.
zaijian~~cool smiley
Edited 3 time(s). Last edit at 09/04/2007 08:40PM by china_poppi.
Re: WordRider Questions...
September 04, 2007 08:59PM
hi smiling smiley
Thank you too smiling smiley.
> WordRider:
> the calc~?!!
Usually yes, but you can try to use this utility to add Hibview under APPS button:
[www.ticalc.org], but I didn't test it.
It's a bit necessary to understand how it works 'inside'. This topic should help you to understand it:
No problem smiling smiley.
Thanks for using WordRider
Vity
