HELP
May 02, 2009 07:31PM
Hi.
pobrałem ten fajowy programik i gdy chcę go włączyć to pojawia mi się ekran powitalny, potem znika i nic się nie dzieje.
Jave mam zainstalowaną tą co trzeba
(i'm not sure that my english is good)
I charged this cool program and when I want to start i see a welcoming screen, then he is disappearing and nothing is happening. I have installed Java with the one what it is necessary
Re: HELP
May 02, 2009 07:38PM
ESET Antivirus?
I need to see your app.log file to help you...
Please read readme.txt.
Edited 1 time(s). Last edit at 05/02/2009 07:38PM by Vity.
Re: HELP
May 02, 2009 07:49PM
yes i've got eset smart security and i've read something about this antivirus and i closed all his functions and nothing happens
how can i get this log file??
Re: HELP
May 02, 2009 07:59PM
Problem: ESET "Smart" Antivirus on Windows OS blocks FRD to start
Solution: make correct settings of your antivirus program or run FRD this way:
frd.exe -Doneinstance=false
Re: HELP
May 02, 2009 08:12PM
i don't understand this how to do it
i [szat] down all functions of eset and nothing happeans
Re: HELP
May 02, 2009 09:09PM
See this thread:
