FRD freeze after start
January 31, 2016 04:09PM
After start of program it freeze completly (after the main window is showed) and I had to kill the java process. It was shortly after I updated to latest Java, so I spent half an hour to reinstaling java (several times and end with 1.8.0_71) and deleting all program directory files and re-extractig program again. Still no luck.
Finally I found that program plugins are stored in c:\Users\%userName\AppData\Roaming\VitySoft\FRD after delete it. It's all fine, even after I update all pugins.
Please add this to known bugs to save time to other people.
Re: FRD freeze after start
January 31, 2016 05:57PM
The AppData folder also stores program settings and the download list and history. There is also a log file, which may contain information about the problem.
February 07, 2016 03:33AM
There is bug in FRD, on startup if you have large number of items, it will take a long time to load, almost like freezing. This will be fixed in the next release.
Edited 1 time(s). Last edit at 02/07/2016 03:34AM by tong2shot.
aej
February 10, 2016 03:57PM
I have the same issue with the two last update. Already tried a few things; but can't make it work anymore.
I tried to clean the plugins as mentionned by chashitsu; but it's not working for me ...
so sad ....
aej
February 10, 2016 04:04PM
I found on another post the solution ; at least for me.
I had to delete the .odb et .odb$; in the log file it was said to be inconsistent.
Working again ...
April 25, 2016 05:47PM
> for me.
> Working again ...
it work
But if i deleted this files i'll lose all my list of downloads...
can anyone help me? i'm having the same problem mentioned here.
but i dont wanna lost my list of downloads...
i have used FRD for many years.
now i'm thinking to try another downloader program
because of this error
April 25, 2016 06:29PM
Mon Apr 25 15:26:38 BRT 2016 WARNING: Detected ESET - disabling OneInstance functionality
Mon Apr 25 15:27:08 BRT 2016 WARNING: Couldn't create fir C:\Users\..........\AppData\Roaming\VitySoft\FRD
Mon Apr 25 15:27:14 BRT 2016 SEVERE: Status code je 500
Mon Apr 25 15:27:55 BRT 2016 SEVERE: Status code je 500
Mon Apr 25 15:28:04 BRT 2016 SEVERE: Status code je 500
Mon Apr 25 15:28:14 BRT 2016 SEVERE: Status code je 500
Mon Apr 25 15:28:22 BRT 2016 SEVERE: Status code je 500
