FreeRapid Downloader 0.83 beta versions July 19, 2009 05:05PM |
frd.exe --portableswitch, which is using separate directory for configuration files.
, find reproducible bugs and report it here. Please, don't ask for new features in this topic (I already have my TODO list full for next 2 years...).
4th October 2009 - FreeRapid Downloader 0.83 Release Candidate 2 Changed : minor internal changes in plugins API Changed : optimizations: minimized size of SwingX library Changed : updated plugins to their latest versions Changed : new cancelOnEscape internal property to disable ESC keystroke for action Cancel 20th September 2009 - FreeRapid Downloader 0.83 Release Candidate Added : startup.properties file in FRD's directory - see comments in this file for more details Added : registered new Substance 5.3 themes - Gemini, Magellan, Graphite Aqua Changed : minor GUI speed optimizations Changed : upgraded Substance LaF to version 5.3 Changed : updated plugins to their latest versions Fixed : Close To Tray bug [bugtracker.wordrider.net] [thanks to kiwichick!] Fixed : restore window size to maximized state does not work 5th September 2009 - FreeRapid Downloader 0.83 beta 4 Added : improvements and fixes to enable FRD using blind people - it's now compatible to Java Accessibility Bridge - See [java.sun.com] for more details or here: [a11y.netbeans.org] Added : SOCKS proxy support [thanks to Benjamin!!] - all urls in proxy list file has to be prefixed with $SOCKS$ or SOCKS: proxies using port 1080-1090 are marked as SOCKS automatically; SOCKS5 authentication is experimental, Added : added shell script setupproxy.sh in tools/socks to help with automatic creating list of SOCKS proxies for FRD [thanks to Benjamin!!] Added : added backup links.txt file (located in configuration folder), which stores all links you ever added into FreeRapid Fixed: problems with backup files 30th August 2009 - FreeRapid Downloader 0.83 beta 3 Added : error message when launching FRD on GCJ Changed : connection timeout set from 100 to 120 seconds Changed : updated default plugins to their latest versions Changed : internal - Windows - removed dependency on Windows registry Changed : internal - upgraded SwingX components to the latest build Fixed : selection disappears - when making selection from top to bottom while downloading Fixed : cannot launch CANCELLED (but existing) files Fixed : "checking... dialog" when updating plugins lies over dialog "checking finished" - finally fixed?! Fixed : If you change preferences check for updates every 597 hours or more FRD cannot start [reported by Prthvi, thanks!] 9th August 2009 - FreeRapid Downloader 0.83 beta 2 released Changed : updated PT_BR translation thanks to Tiago Changed : support for speed limit from menu (additional support will come back with 0.84) Changed : upgraded GOCR to version 0.48 Changed : internal - upgraded SwingX components to version 1.0 Changed : updated default plugins to their latest versions Changed : removed error message dialog for ERROR when there is not enough space on disk Fixed : regression - avg. speed disappeared from information dialog [thanks to user from forum] Fixed : "checking... dialog" when updating plugins lies over dialog "checking finished" 19th July 2009 - - FreeRapid Downloader 0.83 beta released Added : support for resuming files for hostings which support it (eg. HotFile, but not Rapidshare free!) Added : quick search (incremental search) for searching in the main queue table and plugins table (ctrl+F) Added : MS Windows - windows key for popmenu emulates a click with right mouse button on content panel with links Added : Apple MacOS - support for native Aqua Look&Feel Added : support for GTK look and feel Added : new frd.sh launching script [thanks to Petris!] Changed : upgraded JTattoo library to the latest version Changed : fatal exceptions are shown only once for reporting Changed : Apple MacOS - screen menu bar used by default Changed : Apple MacOS - menu.about.name - correct title - FreeRapid Downloader + version Changed : upgraded Substance lookAndFeel to version 5.2 + new themes Fixed : ClassCast exception in directory chooser Fixed : handling invalid response header from server with empty file name Fixed : main window couldn't be activated at some random special cases Fixed : NullPointerException when server didn't respond anything at some random special cases Fixed : downloading updates does not work on Windows 7 Fixed : New links dialog - paste from clipboard did not work properly at some cases + some plugin development improvements
Re: FreeRapid Downloader 0.83 beta July 21, 2009 04:33PM |
Re: FreeRapid Downloader 0.83 beta July 22, 2009 04:28PM |
Re: FreeRapid Downloader 0.83 beta July 22, 2009 06:48PM |
Re: FreeRapid Downloader 0.83 beta July 22, 2009 11:31PM |
POST /files/66929529/6506569/ProjectHM6_HMC907045.part1.rar HTTP/1.1 User-Agent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-GB; rv:1.9.0.8) Gecko/2009032609 Firefox/3.0.8 (.NET CLR 3.5.30729) Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8 Accept-Language: cs,en-us;q=0.7,en;q=0.3 Accept-Charset: windows-1250,utf-8;q=0.7,*;q=0.7 Accept-Encoding: gzip,deflate Keep-Alive: 30 Referer: [rapidshare.com] Range: bytes=18835344- Host: rs201l32.rapidshare.com Content-Length: 9 Content-Type: application/x-www-form-urlencoded mirror=onHTTP/1.1 404 Not Found P3P: CP="ALL DSP COR CURa ADMa DEVa TAIa PSAa PSDa IVAa IVDa CONa TELa OUR STP UNI NAV STA PRE" Date: Mon, 20 Jul 2009 14:49:10 GMT Connection: close Accept-Ranges: bytes Content-Type: text/html; charset=ISO-8859-1 Cache-Control: no-cache Content-Length: 33 Do not use download accelerators!
Re: FreeRapid Downloader 0.83 beta July 23, 2009 03:47AM |
Re: FreeRapid Downloader 0.83 beta July 24, 2009 02:08PM |
Re: FreeRapid Downloader 0.83 beta July 24, 2009 07:19PM |
Re: FreeRapid Downloader 0.83 beta July 26, 2009 09:59AM |
Error
Message:
java.util.concurrent.RejectedExecutionException
Level:
SEVERE
Stack Trace:
null
java.util.concurrent.ThreadPoolExecutor$AbortPolicy.rejectedExecution(Unknown Source)
java.util.concurrent.ThreadPoolExecutor.reject(Unknown Source)
java.util.concurrent.ThreadPoolExecutor.execute(Unknown Source)
org.jdesktop.application.TaskService.execute(TaskService.java:116)
cz.vity.freerapid.gui.managers.ProcessManager.startDownload(Unknown Source)
cz.vity.freerapid.gui.managers.ProcessManager.access$100(Unknown Source)
cz.vity.freerapid.gui.managers.ProcessManager$2.run(Unknown Source)
Re: FreeRapid Downloader 0.83 beta July 27, 2009 12:12PM |
