not working need help
Posted by oxey
March 09, 2010 09:18AM
Wording if any one else is having this problem. I've been using this program for a while now but now it's broken. when ever i load it up it freezes up dose not do anything just makes a noise when i click on it any one know how to fix it
Re: not working need help
March 09, 2010 09:27AM
too little information
March 09, 2010 10:31AM
Same here... The last version is crashing before even opening
java se error
im using windows 7 64 home
March 09, 2010 10:45AM
what java se error
March 09, 2010 01:50PM
Oh dear, you guys really are drowning us in information.
March 09, 2010 09:17PM
ok running windows xp
the program was working
but now when i load it up afther about 2 sec it dose nothing when i click on it i just makes a noise bong bong cant move it nothing works just a noise bong bong. i have dleated it servle times and re downloaded it servle times but still the same thing. i get nothing but the noise bong bong. the only thing i can do is right click and exit the program
March 09, 2010 10:26PM
ok more info this all started a cupple of days ago when i tryed to add a lot of links at the same time... now when i start up the program i can get into it but when i try an add anther url that's when it frezes
March 09, 2010 10:32PM
Try to do this:
Go to this folder [wordrider.net] or into its equivalent on Win7 and delete file mainframe.xml
Then start FRD again.
March 10, 2010 10:28PM
ty ty ty ty ty ty ty Vity ty very much that fixed it
March 11, 2010 07:26PM
When I paste an url, it is the same message always : the plugin is not supported and I have updated already but even then noting happens. Please help
