FRD doesn't loads me anymore..
Posted by Jelobije
Zax
Re: FRD doesn't loads me anymore..
May 06, 2009 01:52PM
Vandarte Wrote:
> I think I haven't understood your question very
> well. It's on windowns XP service pack 3 with the
> custom configurations. I was able to finally make
> it work by the prompt cmd. I had to use the
> FRD.jar instead of the FRD.exe. But I saw that the
> option "Allow only one instance" was already off.
> But the program is "on" right now and later I will
> see if I will always need to use the cmd.
> Thanks for the help.
> Now I've tested it, and it's working very well.
> Unclicking "Allow only one instance" must be
> enough to solve it after all. But I'm pretty sure
> I wasn't the one to uncheck it.
> Thanks anyway!
Vandarte e Vity please if can run FRD with ESET put some screenshot to teach how do that Allow only one instance, on ESET because I have try cmd on pront comand and didnt work anything, by the way great work Vity, you got yourself pretty good fans.
Thanx.
Zax
FRD really can run with ESET
May 06, 2009 01:57PM
> Thanks anyway!
Thanx.
May 31, 2009 12:08AM
I have ESS and me helped this (correction post vity)
Start->Run type cmd ENTER"]
cd "YOUR FRD FOLDER PATH" ENTER
Here
frd.exe -Doneinstance=false
Edited 4 time(s). Last edit at 05/31/2009 12:12AM by OSSA.
September 13, 2009 10:25AM
hi,
i have this problem in windows 7
It was working before formating my pc
my friend have win 7 but it is working
I did the steps written previously but no hope
please HEEEELP
by the way
This prog Crack the mind!!!!!!!!
September 13, 2009 10:29AM
upload a log file or try 0.83beta4
Edited 1 time(s). Last edit at 09/13/2009 10:29AM by Vity.
September 13, 2009 12:12PM
ep 6, 2009 6:15:31 PM cz.vity.freerapid.utilities.LogUtils processException
SEVERE:
cz.vity.freerapid.plugins.exceptions.PluginImplementationException: PluginImplementationException
at cz.vity.freerapid.plugins.services.hotfile.HotfileFileRunner.checkNameAndSize(Unknown Source)
at cz.vity.freerapid.plugins.services.hotfile.HotfileFileRunner.run(Unknown Source)
at cz.vity.freerapid.plugins.webclient.AbstractFileShareService.run(Unknown Source)
at cz.vity.freerapid.core.tasks.DownloadTask.doInBackground(Unknown Source)
at org.jdesktop.swingworker.SwingWorker$1.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at org.jdesktop.swingworker.SwingWorker.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
is this what u want or??
September 13, 2009 12:51PM
Hi Vity,
The prog has worked , it was an old version i think so !! i used 0.83 and worked !!
Tkanks 4 every thing
November 11, 2009 03:46PM
> vity)
> Here
Really helpful!
Thanks a bunch!
December 31, 2009 09:07AM
FRD doesnt loads me anymore... and i dont know how to use the command.. can you show me how to using the command include the pictures too...thumbs up
March 17, 2010 07:36PM
Hi... First thing first; Sorry for my english.
I had the same problem. Formatting my PC... etc., etc.
First, I don't know what is going on. After installation of Eset NOD32, FRD only works by cliking the FRD Jar file.
Later, after installation of Eset Smart Security... didn't work at all. The frd.exe -Doneinstance=false didn't work either.
I decided to unistall Eset Smart Security. Then, without any antivirus, I opened (at last) FRD and deactivated "Allow only one instance". Later, I installed ESS again... and now everything is working Ok...
I hope this was helfull...thumbs up smiley
