FRD doesn't loads me anymore..
Posted by Jelobije
Re: FRD doesn't loads me anymore..
October 20, 2008 08:57PM
Vity Wrote:
X-----------------------------------------------------
> Someone already tried to do that:
> [www.wilderssecurity.com]
> The antivirus considers the FRD's behaviour as an
> attempt to create server (as trojans do). They
> won't change it. You just need to allow FRD to do
> that, otherwise functionality "Allow only one
> instance" won't work - it's Java way.
> FRD is no malware/spyware or any *ware...
Yes, I know it, I'm the reporter smiling smiley
When I disabled the "Allow only one instance", it worked.
But problem is, that ESS doesn't ask when FRD is trying to act as server, so I cannot allow it. Even when I disabled antivirus and firewall completely, it did not work. Only way is killing AV's the main process.
So, we will see...
Regards
Tom
Edited 3 time(s). Last edit at 01/05/2009 12:48PM by Vity.
November 12, 2008 11:01PM
or use avast antivirus for home for free
WtS
December 19, 2008 01:55PM
Sorry only in Czech language....i haven´t not free time
Options ESS Before launch FRD
1/ right click to iconu ESS -> Detail options
2/ find Personal firewall -> left click
3/ rozbal lištu Režim filtrování a zvol Interaktivní režim -> potvrdit OK
4/ rozbal FreeRapid-0.71.zip a dej si na plochu ikonu frd.exe
5/ spusť FRD 0.71
6/ objeví se několikrát interaktivní okno ESS
7/ dej volbu zapamatovat napořád + povolit
a to je vše
8/ podobným způsobem můžeš vrátit nastavení ESS na Automatický režim, ale tvá volba zůstane zapsána v pravidlech připojení ESS
pokud už ale ESS zablokoval FRD musíš odinstalovat ESS resetovat PC a nainstalovat ESS znova. Pak postupuj dle návodu výše.
Edited 1 time(s). Last edit at 12/19/2008 01:59PM by WtS.
December 19, 2008 05:29PM
Happy using ESS grinning smiley
December 24, 2008 10:11AM
Vity Wrote:
> So you have 2 choices:
> 1) Make correct settings of the antivirus, because
> it blocks FRD in correct functionality.
> or
> 2) Start FRD from command line:
> frd.exe -Doneinstance=false
> (only once is enough)
It was working with 0.71 but doesn't works with 0.8. Gives the following error:
C:\Program Files\utils\FreeRapid>java -jar frd.jar -Doneinstance=false --debug
java.io.IOException: Log properties file was not found: logdebug.properties
at cz.vity.freerapid.utilities.LogUtils.initLogging(Unknown Source)
at cz.vity.freerapid.core.MainApp.initialize(Unknown Source)
at org.jdesktop.application.Application$1.run(Application.java:173)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
2008.12.24. 9:46:32 org.jdesktop.application.Application$1 run
SEVERE: Application class cz.vity.freerapid.core.MainApp failed to launch
java.lang.IllegalStateException: Config property Application.ID is empty!
at cz.vity.freerapid.core.AppPrefs.(Unknown Source)
Exception in thread "AWT-EventQueue-0" java.lang.Error: Application class cz.vity.freerapid.core.MainApp failed to launch
at org.jdesktop.application.Application$1.run(Application.java:180)
Caused by: java.lang.IllegalStateException: Config property Application.ID is empty!
... 8 more
There is no error output with 'frd.exe --debug' though. I had removed settings folder but error was the same. I am using ESET NOD32 but older version was working so this might not related to NOD32. I have deleted the 0.71 zip so please make accessible older versions. Thanks!
BTW, your program is absolutely a masterpiece! Keep up the good work!
December 24, 2008 12:07PM
You probably didn't extract the zip file properly. You have to have /lib directory with all libraries in the freerapid directory.
December 25, 2008 01:30AM
Damn! You are right, thank you! I have accidentally turned off single file compare in Total Commander so new files weren't noticed and copied... Everything is working now.
February 27, 2009 09:47AM
Please, I can't make it work at all. I have ESET and I think this may be the problem, but the strange thing is that it worked very well the first time i used, I realy need this program back.
I have tried the command prompting, and nothing, happens the same thing as the normal icon in windowns, just flashes the Java icon.
I tried to adjust the ESET configuration (i won't get rid of eset, it's has been helping me until today) but, I'm brazilian and I can't undrestand a word in Czech, can someone please tell me a way to make eset and Freerapid stop figthing? I nedd them both.
How do I put this option "Allow only one instance" off if I can't have access to the program at all?
Thanks for the help.
February 27, 2009 10:58AM
Where do you have the ESET antivirus installed?
Can you post a log file here, please?
Edited 1 time(s). Last edit at 02/27/2009 10:59AM by Vity.
February 27, 2009 04:03PM
I think I haven't understood your question very well. It's on windowns XP service pack 3 with the custom configurations. I was able to finally make it work by the prompt cmd. I had to use the FRD.jar instead of the FRD.exe. But I saw that the option "Allow only one instance" was already off. But the program is "on" right now and later I will see if I will always need to use the cmd.
Now I've tested it, and it's working very well. Unclicking "Allow only one instance" must be enough to solve it after all. But I'm pretty sure I wasn't the one to uncheck it.
Thanks anyway!
Edited 1 time(s). Last edit at 02/27/2009 10:15PM by Vandarte.
