Re: Rapidgator premium plugin not working July 10, 2017 09:08PM |
as stressed in my previous post;Quote
1. Clearly state your OS version/architecture
3. If on Windows , launch Java Control panel, select Java tab, press View button and check that
JRE 8u131 is the only runtime selected/enabled (if more present) in both User/System tabs.
5. Provide specific link you're having trouble with - does the same link work with the free rapidgator plugin (1.1.14) ?
8. If you have quite a large number of active downloads, then maybe try to fetch them in batches of two...
9. Provide your full unedited debug log with your failing link - don't edit out portions of it yourself, except for, maybe,
your machine account username and your premium RG credentials; tong2shot specifically requested the section
of the log where the JRE used by FRD is mentioned - do you see that anywhere in the excerpt of the log
you attached?
http://rapidgator.net/file/7b99b92a984db8e4c5c00d3aafcb697b/Of course, trying to down that with the free plugin fails, but at least my DEBUG app.log starts with
Mon Jul 10 23:36:42 EEST 2017 INFO: Config files directory: F:\Applications\FRD\FreeRapid-0.9u4\config Mon Jul 10 23:36:42 EEST 2017 INFO: You are running FRD with JVM version = C:\Program Files\Java\jre1.8.0_131 1.8.0_131 - (min 1.6.0_07 is required) Mon Jul 10 23:36:42 EEST 2017 INFO: Testing existing instance Mon Jul 10 23:36:43 EEST 2017 INFO: No other instance is running. Mon Jul 10 23:36:43 EEST 2017 INFO: Creating a local socket server Mon Jul 10 23:36:43 EEST 2017 INFO: Waiting for connection
7. As pointed already, if you're on a MacOS and using the app, these tend to use the Apple (system) supplied (old) version of Java 6, even if the latest version from Oracle is installed...
Re: Rapidgator premium plugin not working July 10, 2017 09:15PM |
Re: Rapidgator premium plugin not working July 10, 2017 10:32PM |
java -versionin the terminal; what is that, please?
java version "1.8.0_131" Java(TM) SE Runtime Environment (build 1.8.0_131-b11) Java HotSpot(TM) Client VM (build 25.131-b11, mixed mode, sharing
Re: Rapidgator premium plugin not working July 10, 2017 10:35PM |
Re: Rapidgator premium plugin not working July 10, 2017 10:38PM |
Re: Rapidgator premium plugin not working July 10, 2017 11:28PM |
Re: Rapidgator premium plugin not working July 11, 2017 12:06AM |
Re: Rapidgator premium plugin not working July 11, 2017 01:44AM |
[docs.oracle.com] [docs.oracle.com] [docs.oracle.com] [docs.oracle.com]It may be necessary to install full JDK8 rather than simply JRE8...
Re: Rapidgator premium plugin not working July 11, 2017 10:41AM |
Re: Rapidgator premium plugin not working July 11, 2017 03:14PM |
